Replacement Gas Jets for Natural Gas Hob
space-for-grace@hotmail.c
by space-for-grace@hotmail.c » Sun Jan 18, 2009 8:20 am
Help!! - I have a Kuppersbusch GKS 324.0 hob which was converted from natural gas to lpg. I now want to reconver to natural gas but can only obtain one of the gas jets from Kuppersbusch as they no longer supply them. I need a single replacement jet for the high-speed burner 2.9 kw. Does anyone know where I can get one or if there is a compatible that I can obtain from somewhere? Thank you.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 11:21 am
by space-for-grace@hotmail.c » Fri Jan 30, 2009 4:32 pm
This was the first thing I tried - no luck.
AdamsHeating
by AdamsHeating » Sat Jan 31, 2009 1:10 pm
This might sound stupid, but have you contacted the person who fitted the hob?
As a matter of course I tend to keep hold of the spare injectors for occasions like this but I don't have the ones you are talking about as I only install natural gas and not lpg, hence I have a draw full of spare LPG injectors!
the installer may have kept them for such an occassion...? it's woth a call?
regards,
AH.
It is currently Wed Jan 15, 2025 9:20 am
