Pull cord light
djl
Pull cord light
by djl » Sun Jan 18, 2009 5:10 pm
The pull cord light in my garage only works intermittently particularly when turning it off. I often have to climb up a stepladder to pull it close to the top and even that can take several attempts. I have unscrewed the cover and removed any dust and fluff but it made no difference. Can anyone suggest what is likely to be causing it to work sometimes but not others?
by ericmark » Sun Jan 18, 2009 8:54 pm
It is worn out. Sorry to say in most cases only cure is new switch.
djl
by djl » Sun Jan 18, 2009 9:29 pm
Thanks for your response. A new one is cheap enough to buy anyway but I wanted to check first if there was any other likely cause of the problem. Your advice is appreciated.
It is currently Fri Jan 31, 2025 10:49 pm
