Gainsborough 9.5 delux
Kully
by Kully » Mon Jan 19, 2009 2:31 pm
Hi I have a problem with my Gainsborough shower on the cold setting the pressure is fine however when i increase to a warmer setting the presssure drops dramicticly. (just a dribble)
It has been working fine previously!
Can any one help!! Thanks
plumbbob
by plumbbob » Mon Jan 19, 2009 11:38 pm
Electric showers control the water temp by increasing or decreasing the flow of water over the element. All electric showers can be turned to a point where the water is almost a dribble but you could not use it as a shower because apart from the flow, the water would be too hot.
If you have a good flow of water when the knob is turned to cold, but cannot get a good temp without reducing the flow to just a dribble suggests one of the heating elements is not working.
If you have a half power and full power control button, see how the different settings alter the temp.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:14 pm
It is currently Thu Jan 30, 2025 11:55 pm
