Gravel driveway on sand sub-base
scowley
by scowley » Wed May 16, 2007 9:27 pm
I live in an area where the ground is mainly sand, i have dug out for my gravel driveway, but am wondering as the ground is pure sand (not gritty sand) whether i should just compact it all down with a wacker plate then put 1.5 or so of gravel straight on top?
Simon
thedoctor
by thedoctor » Fri May 18, 2007 7:47 pm
Much better to dig down to a solid base. Sand is no kind of base for a driveway no matter how hard you compact it. The water will drain through or down the sides of the top layer of drive and when it gets into the sand it will follow all ground slopes. This will cause little rivulets in the sand which will very soon undermine the drive.
scowley
by scowley » Sun May 20, 2007 10:05 am
Thanks for that... the problem is it is purely sand - what depth would be recommended to dig down to, say if i dug down 6 inches and put 3-4 inches of crushed concrete would that give me a suitable sub base?
Simon
It is currently Fri Jan 31, 2025 1:56 am
