wires are to short
ptek2004
wires are to short
by ptek2004 » Mon Jan 19, 2009 8:33 pm
I am replacing a standard double 13a wall plug socket with a double rcd socket as I am running an 8 plug extension for the tv, sky, dvd etc. I figure the rcd will be a safer way to go. My question is I removed the socket and went to fit the RCD but the live wire wont reach. Is there a safe way of extending the wire? only thing that i can think of is solder and lots of insulation...
many thanks
pj
kbrownie
by kbrownie » Mon Jan 19, 2009 10:29 pm
You can crimp the joint with a coupler or you can use a conection block and wrap it in insulation tape as it is in the back box of a socket, it will be accessable for inspection.
KB
by sparx » Mon Jan 19, 2009 11:13 pm
A large connector block would be OK in the back box with a short length of extra wire as it can be checked for tightness easily later. Crimping with car type crimps not recommended, nor soldering.
regards Sparx
It is currently Sun Jan 19, 2025 2:17 pm
