Knauf Space Blanket
Did it myself
Knauf Space Blanket
by Did it myself » Tue Jan 20, 2009 3:44 pm
Anybody have experience of using Knauf SpaceBlanket insultation? Do you really need to make sure all electrical cables are above the insulation?
All wiring in my loft is currently under boarding so can't see the need to do this?
Any advice before I start this job?
by stoneyboy » Wed Jan 21, 2009 11:24 pm
Did it myself,
The important thing is not to encapsulate your wiring in the middle of insulation - it needs to be touching plasterboard or similar on one side.
Did it myself
by Did it myself » Fri Jan 23, 2009 2:09 pm
Stoneyboy,
thanks for your response, but just to be clear, do you mean the wiring needs to be touching plasterboard (or similar) on one side? i.e. as long as the wiring isn't running through the insulation?
by stoneyboy » Fri Jan 23, 2009 6:16 pm
Did it myself,
Yes sorry its the cable which must be touching.
It is currently Tue Nov 26, 2024 6:33 pm
