Block wall
trevors50uk
Block wall
by trevors50uk » Thu May 17, 2007 9:01 am
When building a block retaining wall approximately 4 foot tall with soil behind to 3 feet does the wall need to be double thick?
thedoctor
by thedoctor » Fri May 18, 2007 7:53 pm
Depends how thick the blocks are really Trevor! If you are using standard 4 inch blocks then it would be best lay them flat making a 9 inch wall.
sparkyjnr
Re: Block wall
by sparkyjnr » Tue Apr 08, 2008 5:12 pm
[quote="trevors50uk"]When building a block retaining wall approximately 4 foot tall with soil behind to 3 feet does the wall need to be double thick?[/quote]
Did you build the wall? if so, single or double thickness? I have a similar job to do!
It is currently Sun Dec 22, 2024 1:27 pm
