downlighters
munster65
downlighters
by munster65 » Wed Jan 21, 2009 7:24 pm
just installed two sets of 5 downlighters,plus transfomers,both worked for 24 hrs.
Now only one set works
Any ideas
singer
by singer » Thu Jan 22, 2009 12:00 pm
Have you matched the wattage of the lamps to the max wattage output of the transformer - if not could be transformer blown due to overload.
If not could be loose connection in junction box on supply cables to trnsfmrs - check you have supply to all trnsfmrs - live AND neutral.
Its got to be something simple if they were working 1 day ago - too much of a coincidence to be all lamps gone but do check.
Post back if still not working after you've checked all of the above.
It is currently Sun Jan 19, 2025 2:10 pm
