Problem with Potterton Netaheat Boiler
max5445
by max5445 » Thu May 17, 2007 11:49 am
Can anyone give me advice on my boiler - the light ignites when i use hot water, however when it comes to my radiators the light does not ignite and my radiators remain cold. any advice would be appreciated.
Arnak
Boiler problem
by Arnak » Thu May 17, 2007 11:49 pm
I know this is probably a daft suggestion but is the room stat turned down too low?
It could also be a temperature sensor that is faulty in the boiler.
If it not the room stat then I would recommend a corgi registered fitter having a look at the boiler.
Arnak
It is currently Tue Nov 26, 2024 8:15 am
