Solenoid valve replaced but now water trickles out?? Help
robmaidment
by robmaidment » Thu Jan 22, 2009 8:35 pm
Hi, our shower started leaking last week so we replaced the solenoid valve which was faulty, now its all back together the power shower (Triton I may add!!) is now only trickling out water...any idea on what has happened?? How do I get it running properly? Any advice appreciated
plumbbob
by plumbbob » Fri Jan 23, 2009 12:25 am
I would guess it is probably airlocked. Try and flush the pipes to force the air out. DO NOT RUN THE PUMP DRY or you will be buying a new one.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:21 pm
It is currently Wed Nov 27, 2024 4:16 am
