Smell coming from kitchen sink
KHE
by KHE » Fri Jan 23, 2009 8:57 am
Please can you help? I have a dreadful smell coming from the sink in the kitchen. The drain is not blocked as the water is flowing freely, the smell is especially bad in the am. I have tried everything. Have you any ideas
thedoctor
by thedoctor » Fri Jan 23, 2009 9:57 am
HI take a look at our projects section and go to the projects on waste pipes. IE Waste Traps, how they work.
https://www.diydoctor.org.uk/alphasearch/W.htm
When you get a full understanding of what should be happening with your system you may be able to figure out what is going wrong. For a smell to be getting back into the kitchen then it must be by-passing the trap somehow. This may mean you have something connected to the waste above the trap (washing machine ?).
Stelf
by Stelf » Fri Jan 23, 2009 4:48 pm
Hi KHE,
The Doctor could be right but sometimes sink traps do smell a bit. Try taking the trap off and cleaning it up and a regular dose of Domestos tipped down the sink and left for some time before running any water through works wonders.
Best wishes
aceone
by aceone » Fri Jan 23, 2009 5:57 pm
hi... try a bit of bleech overnight
It is currently Mon Nov 25, 2024 9:57 pm
