Boiler Hot Water
skyman1000
Boiler Hot Water
by skyman1000 » Sat Jan 24, 2009 4:17 pm
I have a Woster Bosch 28CDi combi bolier and i have found that in my kitchen it takes some time for the hot water to come through. I have been told it might be the 'heat exchnage' due to lime scale build up parts about £180-£200 + fitting is this right.
Is it worth fitting a anti lime scale device would this cure my problem the cheaper way?
Any help must appreciated
Thanks :roll:
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:24 pm
It is currently Thu Jan 30, 2025 11:41 pm
