flaking plaster on a ceiling
tcj
by tcj » Sat Jan 24, 2009 4:37 pm
I have a ceiling that has been papered. Taking some paper off, the plaster underneath has lots of cracks, so that the plaster looks as if it is "flaking" off. The cracks are running in straight lines, possibly along where plasterboard sheets join.
Is the answer to replace the ceiling or can we fill / replaster the ceiling??
Tim
kbrownie
by kbrownie » Sat Jan 24, 2009 6:16 pm
You can replaster it, the boards have started to sag which has caused the cracks, this is not unusual as ceilings used to be nailed up and the weight of the board + plaster would force nails to pull away. You now need to find all you timber joist and screw (not nail) the ceiling back up tight, then tape over all cracks. Then it can be replastered, alternative if ceiling is not fit to replaster. Is board over the hole ceiling this will mean you will not need pull it down (messy Job) and plaster over that or joint fill.
KB
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 2:27 pm
It is currently Sun Nov 24, 2024 9:16 am
