installing rooflight
greengrass
by greengrass » Sun Jan 25, 2009 9:16 am
Sounds and probably is a silly question.
Bungalow roof.
Do rooflights fit ON the rafters or between them.
Mine are 16" -18" centres of truss roof construction style call 'FINK'
If the roof light can be put on the trusses not between saves a problem needing to get light and air into a bedroom of bungalow with outside window in conservatory [only way to get a decent sized conservatory].
Roof tiles are Bold roll interlocking over felted rood. The narrowest opening outward would be able to see edges of trusses but don't bother me.
Many thanks to responders for comments good or bad.
swidders
by swidders » Mon Jan 26, 2009 12:20 am
They sit on the rafters
greengrass
by greengrass » Mon Jan 26, 2009 2:13 pm
Many thanks Swidders saved a big problem and cost of having one made to fit between.
Will be starting when gauranteed dry weather.
Greengrass
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:22 am
It is currently Fri Nov 22, 2024 7:38 am
