Cold Radiator and Pipes
LouBUrt
by LouBUrt » Sun Jan 25, 2009 12:34 pm
The upstairs rear bedroom radiator is cold and the pipes leading to it are also cold. The radiator is mostly turned off, not sure if this is significant or not.
On advice we have tried testing the TRV valve - seems to move freely - and yesterday turned off all the other radiators at both valves to try to pump the hot water towards the cold radiator. No luck! Remains adamantly cold.
We turned the pump in the loft to its highest setting. Still no luck.
Any ideas would be welcome. :)
Stelf
by Stelf » Sun Jan 25, 2009 7:40 pm
Try the simple things first. Bleed the radiator, if this doesn't work take the top off the TRV by unscrewing the knurled nut just under the thermostat asssembly. You don't have to turn any water off and it should come off fairly easily without any tools. If not carefully remove using a suitable spanner. You will see a small pin protruding from the centre of the valve. Lubricate this pin just slightly and gently tap (as they often stick) and make sure it goes up and down freely. Replace the top of the valve and set as you wish. Should do the trick.
Best wishes
bobplum
by bobplum » Sun Jan 25, 2009 7:49 pm
hi
probarly the valves are siezed even thou the trv turns if its been off for a while
also the system may need balancing see the projects page
good luck
bob
LouBUrt
by LouBUrt » Tue Jan 27, 2009 7:19 am
Many thanks for the replies - I'll give both suggestions a try at the weekend. Fingers crossed
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:30 pm
It is currently Sun Nov 24, 2024 12:35 pm
