Garage Insulation
markandjac
Garage Insulation
by markandjac » Sun Jan 25, 2009 5:57 pm
I have a detached garage which is fairly 5 years old. It is built in a single course brick (apart from the gable and piers). I keep my classic car in there and use it as a workshop. My problem is that when I heat the garage from cold I naturally get condensation which soaks my beloved car and tools etc. I have a dehumidifier but it's not much help really.
I need to know the best way to insulate against this and it seems that something like Gyproc Themaline might do the job?
If this is correct, should it be fixed by dot and dab or battens?
Should the exterior wall be fitted with vent bricks to allow the new cavity to dry?
Any advice would be appreciated
Mark
by stoneyboy » Mon Jan 26, 2009 9:11 pm
markandjac,
Fix the boards to the walls using treated battens, use treated timber at the bottom of the boards to keep them off the floor and ventilate the cavity. Keep using the de-humidifier.
Should have added that you need to use segmented battens to aid ventilation and probably 2 low level and 2 high level vents on ech side of the garage.
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 2:28 pm
chris_on_tour2002
by chris_on_tour2002 » Tue Jan 27, 2009 3:42 pm
insulation will not stop the condensation - in fact it could heighten the problem by trapping the damp.
the way to stop the condensation is cross-ventilation. get that sorted before insulating.
markandjac
by markandjac » Tue Jan 27, 2009 7:15 pm
Thanks for the guidance Stoneyboy.
Mark
It is currently Sun Nov 24, 2024 9:45 am
