Large plaster cracks!!
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
7 posts   •   Page 1 of 1
Jimbo2008
by Jimbo2008 » Tue Jan 27, 2009 8:04 am
I built my conservatory last year, the dwarf wall was made up of brick externally and lightweight block internally which is plastered. From then until now cracks have appeared and got worse in the 2 internal corners furthest away from the house. Also my skirting scribes have also opened up (gutted, I got them perfect as well). One corner has got really bad and the crack and scribe has opened up by about 10mm. The external bricks have absolutely no cracks at all and all mortar joints are intact.
Any ideas??
by stoneyboy » Tue Jan 27, 2009 9:54 pm
Jimbo2008,
Did you build a foundation for the inner and outer walls and is the conservatory mounted on the inner or outer wall?
Jimbo2008
by Jimbo2008 » Wed Jan 28, 2009 3:54 pm
I used a raft foundation and the conservatory is mounted on the outer brick wall and the inner plastered block wall is capped off with a cill board.
by stoneyboy » Wed Jan 28, 2009 6:35 pm
Jimbo2008,
In that case the most likely cause is that the blocks were wet when laid and a strong mortar mix was used. Shrinkage is now occuring and is concentrated in one area because of the strength of the wall.
Sorry - probably not the answer you wanted.
Jimbo2008
by Jimbo2008 » Thu Jan 29, 2009 6:55 am
Hi, thanks for your comments. I did wonder if the blocks were able to shrink. At least it can be remedied easily enough, it's just a bummer having to re-do my skirting.
Thanks again
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 8:59 am
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 9:27 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Tue Nov 26, 2024 11:47 pm
