Fitting kitchen / bathroom plinths
otherton
by otherton » Thu May 17, 2007 7:31 pm
Hi All,
I'm fitting some units in an ensuite to take a basin. I'm having problems with the plinth as it has two returns on it, therefore giving me two external corners to deal with. I've tried mitres, but the laminate chips and gettinga tight fit is impossible. Should I just butt them, and use edge tape on the exposed end of the main front piece?
thedoctor
by thedoctor » Fri May 18, 2007 8:37 pm
Either that or use a timber corner piece moulding. These can be bought in any DIY store.
will_buckley
by will_buckley » Tue May 22, 2007 10:43 pm
or if u havnt fitted the worktop yet or you have alot overhangin on each end, you can fit end panels, i use them on all kitchensthen u only have plinths showing at the front.
It is currently Fri Nov 22, 2024 4:18 pm
