Where should the wires go?
febwgdk
by febwgdk » Thu Jan 29, 2009 2:27 pm
General Question: Where should the wires go? Looking at how my house is wired, it looks like lights and switches are served via the ceiling and sockets via the floor. Is this how it must be.
Specific Question: Must the wire from my CU to my new shower's pull cord switch go via the ceiling, or can it go under the floor and then up the wall?
Cheers.
SparkyPaul
by SparkyPaul » Thu Jan 29, 2009 10:00 pm
The wires can go anywhere in the safe zones ie horizontally or vertically between accessories etc
If it is twin and earth burried in a wall less than 50mm then it needs to be 30milli amp or less RCD protected too
A shower needs to be <=30milliamp RCD protected anyway
Is notifiable under part p too for england or wales.
kbrownie
by kbrownie » Fri Jan 30, 2009 12:34 pm
SparkyPaul is right, but the longer your cable the higher the resistance and the higher the voltage drop.
KB
febwgdk
by febwgdk » Fri Jan 30, 2009 2:20 pm
Ta very much.
It is currently Sat Nov 23, 2024 9:08 am
