Do i need to damp proof my internal walls ?
shreddie102
by shreddie102 » Thu Jan 29, 2009 10:03 pm
I have a victorian school with a slate damp course in the external walls. I am planning on putting in a damp course into the mortar above the slate damp course of these walls.
My question is do i need to put the damp course into the internal walls as well as the external walls , seeing as these internal walls are also sitting the earth below ?
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:25 am
Inform Timber and Damp
by Inform Timber and Damp » Sat Jan 31, 2009 1:10 pm
A damp proof course is installed to protect against rising damp, rising damp will therefore affect internal walls - infact will tend to affect internal solid walls more. External walls will tend to be affected by penetrating damp and condensation, therefore i would advise that you have to identify the cause of the damp before spending on a type of action.
fix
by fix » Thu Feb 05, 2009 9:12 pm
I have abit of rising damp on an internal wall. It comes about 30cm up from ground level and I guess it's from the cellar.
I'm abit worried about injecting a damp proof course into the wall and the damp going elsewhere under the floor,can anyone tell me if I should be worried or will it be ok?
It is currently Tue Nov 26, 2024 5:50 pm
