by Perry525 »
Tue Feb 24, 2009 8:33 pm
It is a fact that walls are full of holes.
The traditional finish was wet plaster, that nicely filled all the holes.
From that we moved on to cheap dot and daub plaster board, cheap for the builder that is.
For the person living there, hell!
As the gap between the wall and board is ideal for the wind to blow behind and works like a refrigerator.
To help make matters worse, builders incorporate drips in the outer wall, to facilitate the wind blowing inside the cavity, just to pile on the misery.
In effect you have but one line of blocks between you and the sky.
At least in the early days cavities were sealed and the two inch gap provided a simple buffer, albeit that convection still stripped the heat from the inner wall.
The perfect solution is to drill holes at 18 inch centres and to fill the cavity with polyurethane foam, that's not the space between the wall and plasterboard, as the foam will expand and force that off.
Otherwise traditional wet plaster.
