by DEEARR2 »
Fri Jan 30, 2009 9:39 pm
Before you can size a boiler you will have to calculate the heating load it will be serving. If your radiators have been correctly sized to suit the areas they are heating ,then the total KW heat requirement can be taken from the total output of all the rads. Information regarding radiator outputs can be supplied by any heating supplier. Do not forget to add an allowance for the Domectic Hot Water if the system is conventional.
