Laying a concrete floor
goryon13
by goryon13 » Fri Jan 30, 2009 7:44 pm
I live in France the kitchen floor has tiles on it but they are put down on earth. I want to lift the tiles and dig out the floor to 4inches and put down concrete, the size of the area is 4 metresX 12Metres can some one tell me how much Sand ,cement and gravel I would need I have tried the calculator but i am not that sure about it. Please help
Goryon13
by stoneyboy » Sat Jan 31, 2009 6:11 pm
goryon13,
If you do as proposed you will need 4.8 cu metres of mix. You could ignore the cement used to make the mix because bulking of the sand will compensate for the extra volume. The sand/aggregate mix should be about 50/50.
BUT
With the area you are describing 4" of concrete will crack and break especially when laid on dirt. I suggest you increase the depth to 6" and incorporate reinforcing mesh in the concrete.
goryon13
Tiling Floor
by goryon13 » Sun Feb 01, 2009 1:54 pm
[quote="stoneyboy"]goryon13,
BUT
end[/quote]
Than You very much I was thinking of making it 6" and putting in reinforcing mesh
Goryon
It is currently Thu Jan 09, 2025 2:46 am
