Drainpipe connection to water butt
johnh
by johnh » Thu May 17, 2007 7:46 pm
I have a metal drainpipe and a large plastic water butt. Is it possible to connect the two so that my gutters' rainwater can be fed into the water butt? I know that plastic downspouts and plastic water butts can be connected, but the search for a connector to feed from the metal downspout to a plastic water butt is proving fruitless.
thedoctor
by thedoctor » Fri May 18, 2007 10:08 pm
Never actually done this job John but it seems that, even with a plastic diverter, you need to cut the down pipe to install. If this is the case would it not be worth changing the down pipe to plastic.
It is currently Sun Nov 24, 2024 5:08 pm
