Valiant 828 Condensing Boiler - Large Noise
soup48923
by soup48923 » Thu May 17, 2007 8:43 pm
I've recently had a new condensing boiler fitted, a Valiant 828 as mentioned and like everyone am extremely pleased with its operation. However when the timer switches the boiler on there is a large noise like a foghorn when it starts up !!! I've listended to it outside and trust me, it is loud. Anyone got any clues why this may be ? :?:
Paul Pepper
by Paul Pepper » Fri May 18, 2007 6:26 pm
Get a corgi man out - you might have a serious problem. Noises like that can be down to undersized gas supplies and any other number of potentially serious problems, so get it seen to.
Paul
toneyt
by toneyt » Tue Jun 26, 2007 9:50 pm
if your gas man has a combustion analyser get him to check the co2 in combustion % as this will indicate if you are burning correctly it should be between 8-9%
ollie83
by ollie83 » Mon Oct 15, 2007 10:36 pm
Get it checked, sounds like low gas pressure. very good boiler though.
Bob Walsh
Re: Gas and Gas fitting
by Bob Walsh » Fri Jan 08, 2010 6:27 am
Using Natural Gas or Propane with a high efficiency boiler is the way to heat your home A hydronic heating system that uses radiant technology is the best heating system that you can have. With proper installation technologies you can be heating your home or business with water that rarely needs to be more than warm in temperature. Because of this a condensing boiler is the heat plant that will produce the warm water you need to heat with at ultra high efficiencies. I have personally installed many of these boilers and have had then running in the very high 90% efficiency range. This will get you the most BTU's possible out of your natural gas or propane.
It is currently Fri Nov 15, 2024 4:01 am
