cast iron fireplace fitting
paulhm
by paulhm » Wed Feb 04, 2009 3:58 pm
I am replacing the cast iron frontage which was started to peal away from the wall, with some 8mm expansion bolts
I need to know if i need to fill the space directly behing the legs for the cast iron surrond which is all in one peice, or can i just bolt it to the wall
the fireback has been filled previously
by stoneyboy » Wed Feb 04, 2009 9:46 pm
paulhm,
Cut back the existing plaster, fit the surround into the recess and bolt back with lugs, then make good the plaster.
paulhm
by paulhm » Thu Feb 05, 2009 10:23 am
do i need to fill in the back of the leg sectios of the cast iron frontage with vermiculite or can i leave the space void?
by stoneyboy » Thu Feb 05, 2009 9:23 pm
paulhm,
I cannot see any advantage in filling any part of the fire surround with insulation.
end.
It is currently Fri Jan 10, 2025 9:56 am
