Pressure reducing valve leaking
JAP
by JAP » Fri Feb 06, 2009 2:55 pm
Hi all,
I have a reliance pressure reducing valve on 22mm pipework which connects to an Ariston unvented cylinder the valve looks like :
http://www.rwc.co.uk/Public/prv/312series.pdf
it has 3.5 bar RWC written on the front of the black cartridge
The valve is leaking from the front end of the black cartridge (not the thread which connects to the brass metal body of the valve). The way I see it I just need to find a new cartridge. I can shut off the water unscrew the cartridge and screw on a new one.
Does anyone have any thoughts on this please, are they any considerations that I should be taking into account?
Any constructive advice will be appreciated,
JAP
by stoneyboy » Sat Feb 07, 2009 9:22 am
JAP,
I'm not sure of the mains feed arrangement with the Ariston cylinder but you may have to drain it to remove the pressure reducer. You will certainly have to release the internal pressure after you have turned off the mains.
Get hold of a replacement pressure regulator preferably one fitted with a pressure gauge - you can then check and adjust if required.
rosebery
by rosebery » Sat Feb 07, 2009 4:01 pm
If you haven't got an unvented ticket I don't think you should be going anywhere near it, frankly.
JAP
by JAP » Sat Feb 07, 2009 5:33 pm
Thanks for your reply Stoneyboy, will investigate further.
regards
JAP
Steve the gas
by Steve the gas » Sun Feb 08, 2009 7:51 am
I'm with Roseberry - get an RGI with a G3 ticket = unvented.
These can be very dangerous if you don't know what your'e doing.
It is currently Mon Dec 02, 2024 10:50 am
