worktop edges
6 posts   •   Page 1 of 1
moxard777
worktop edges
by moxard777 » Sat Feb 07, 2009 7:24 pm
i've put in new worktops and have one exposed end! I'm going to put on a laminate edging strip using contact adhesive, what's the best way to cut/finish it??
plumbbob
by plumbbob » Sun Feb 08, 2009 10:41 am
Snip the excess off with a pair of side cutters and then file the edge to make a smooth finish.
moxard777
by moxard777 » Sun Feb 08, 2009 7:46 pm
[quote="plumbbob"]Snip the excess off with a pair of side cutters and then file the edge to make a smooth finish.[/quote]
side cutters?? what type of file wud u recomend?
plumbbob
by plumbbob » Sun Feb 08, 2009 10:18 pm
Side cutters are, well, wire cutters. Check out product http://www.awin1.com/pclick.php?p=36412 ... 071&m=1228 from Screwfix.
Any fine flat metal file will do such as the from Screwfix.
http://www.awin1.com/pclick.php?p=25065 ... 071&m=1228
The excess can be removed very easily without damaging the laminate, but it may be a good idea to try a test first on a piece of scrap. The difficult part is following the front curve.
rosebery
by rosebery » Sun Feb 08, 2009 10:36 pm
"side cutters??"
Yes I thought the same. Apart from the very obvious and expensive route of a laminate cutter or a festool then you can use the back edge of a sharp wood chisel held flat down on the top and at an angle to cut the protruding edging. Then you can rub off the sharp edge with 340 grit "wet n dry".
Alternatively asharp fine toothed hacksaw blade will also do the trick but you'll probably need to file some of the edging before using the wet n dry.
plumbbob
by plumbbob » Mon Feb 09, 2009 11:32 pm
Trust me, I am no novice at this. It is the standard way of trimming the laminate.
Once you have done a few dozen edges or so, they can be done neater than with a electric trimmer, and not that much slower either!
We bought one of those electric trimmers a few years ago, and we all decided it was rubbish as it often chipped the front edge, and you could never do the last few inches against the wall.
It is currently Thu Oct 31, 2024 6:17 pm
