wiring up flourecent strip lights
bargee5
by bargee5 » Mon Feb 09, 2009 7:05 pm
Hi could some please advise me?
I want to add some 60watt flourecent strip lights in my garageworkshop
1 can I wire them up so that i can then plug them into a 13 amp socket
2 How do you work out the max amount of watts that a 13 amp will
safely take or must they go into a fuse board?
many thanks
singer
by singer » Tue Feb 10, 2009 10:45 am
Lighting plugged into a 13 amp socket is fine.
Connect the lights together with cable or flex, then add a piece of 3 core flex to the last light from the connector block and add a 13 amp plug top to other end. Reduce the size of the fuse in the plug top to 5 or 3 amp and simply plug it in.
Providing the socket you're plugging it into is "health" ie wired in correct sized cable, protected by correct method (ie correctly sized fuse or circuit breaker) and has satisfactory earth loop reading then plugging a few lights into it is not going to overload it.
In theory if each flourescent light drew 1 amp then you could run 13 of them from a 13 amp socket though you might have problems with starting current.
I assume you will only be adding one or two so no prob.
bargee5
by bargee5 » Wed Feb 11, 2009 9:24 am
Hi Singer
many thanks for your reply and information,sounds perfect for me
regards
Camel
by Camel » Wed Feb 11, 2009 1:37 pm
Hi Bargee5, I was just wondering if you had any success with your strip lights?
bargee5
by bargee5 » Wed Feb 11, 2009 7:41 pm
Hi camel
yes I have, connected 4 lights x 60watt to a 13 amp plug with a 5amp fuse then i plug into a 13 amp socket as and when required.I will try six at some stage which is well within the safety limits as i understand
regards
It is currently Fri Nov 22, 2024 10:08 am
