Engineered Oak Flooring
Richy G
by Richy G » Tue Feb 10, 2009 8:54 am
I am about to bond engineered Oak Flooring to a concrete sub floor which adhesive is confimed to be the best ?
thanks
Woody_Dude
by Woody_Dude » Tue Feb 10, 2009 6:35 pm
Have you thought of asking the manufacturer for specs as for best fixing methods, or looking at others of a similar nature and seeing what they saw.
rosebery
by rosebery » Thu Feb 12, 2009 8:50 pm
Yes ask the manufacturer. If you use brand X addy because someone here said so and it turns out the manufacturer says you should use brand Y and things go wrong then you will probably find that the maufacturer will run a mile on the basis that "any warranty is invalidated because you installed it incorrectly".
It is currently Mon Dec 02, 2024 12:48 pm
