Knocking in plastic pipe
aquamech
by aquamech » Fri May 18, 2007 8:23 pm
I have added a small bathroom and get knocking for a couple of secs when the taps are closed (lever action mixer on bath and sink). The hot water although low pressure and low flow is the worse.
I have connected in to the existing copper pipes with Polypipe.
approx 4m under the floor boards, 600mm vertical and 1200mm horizontal with Ts to sink and bath on this leg. Although clipped to the wall I can see the pipe move due to the knocking with the bend at the end of this leg moving approx 1mm on the pipe.
I cannot stop this movement even when I hang on the the bends at each end of the pipe. I have a plastic isolating ball valve in both the 15mm plastic pipes in this horizontal length that is knocking.
any ideas ?
thedoctor
by thedoctor » Wed May 23, 2007 7:32 am
See our project on water hammer
aquamech
by aquamech » Sun Jun 03, 2007 7:06 pm
Hi bought some shock arrestors (1/2 inch BSP x 6 inch long). Fitted in the system as per the instruction.Eleviated most of the hammer but the plastic pipe still moved at the fittings. Stripped it all out and replaced with copper. Now ok. I will ring Polypipe and see what they say.
It is currently Sat Nov 16, 2024 12:40 am
