Plasterboard-covered walls
JohnB333
by JohnB333 » Wed Feb 11, 2009 5:29 pm
I'm new (very!) to this DIY lark and this site is a revelation for tyros like me!
I have a general question relating to fixing items onto a wall. My house is relatively new and I wish to fix a couple of shelves on an internal, load bearing wall. The breeze block wall is covered with plasterboard, (I don't think there is a cavity), and my question is this: After I have drilled the holes, do I insert the plugs flush with the plasterboard or do I push the plug through the board so it is wholly in the wall? My instinct says that if it is the first option then the item would not be secure?
I have searched the Projects but am unable to find an answer. My apologies if I have missed it!
by stoneyboy » Thu Feb 12, 2009 10:34 pm
JohnB333,
Preferably screw into the wall behind the plasterboard but use brackets that have a wide bearing onto the plasterboard or you will pull the brackets through the board.
JohnB333
by JohnB333 » Fri Feb 13, 2009 11:38 am
[quote="stoneyboy"]JohnB333,
end[/quote]
Many thanks, stoneyboy, for your reply. Much appreciated!
rosebery
by rosebery » Fri Feb 13, 2009 10:53 pm
Yes you must go through into the blockwork. If it's a heavy item use a frame fixing. After having drilled the hole then half fill with a chemical anchor, insert the fixing and secure the item. It'll need a bomb to get it out again mind!
JohnB333
by JohnB333 » Sat Feb 14, 2009 1:18 pm
[quote="rosebery"]Yes you must go through into the blockwork. If it's a heavy item use a frame fixing. After having drilled the hole then half fill with a chemical anchor, insert the fixing and secure the item. It'll need a bomb to get it out again mind![/quote]
Great advice roseberry; many thanks!
It is currently Fri Jan 03, 2025 3:49 am
