floating floor
raddish
floating floor
by raddish » Fri Feb 13, 2009 3:11 pm
how can i lay a floating t and g floor over my existing chip bourd bedroom floor do i need to secure at intervalls and do i need to leave expantion gaps. frustrated lady diy er . thankyou.
rosebery
by rosebery » Fri Feb 13, 2009 8:28 pm
I'm not sure I understand why you would want it to be floating. Whilst that is common with laminate not so with T&G. Could you explain a bit please?
raddish
floating floor
by raddish » Mon Feb 16, 2009 3:32 pm
sorry if you didnt catch my drift . my existing floor is large chipbourd flooring sheets fixed directly to the joists,so i do not want to remove these.but want t&g floorbourds so i can paint the floor. my dilema is do i fix each bourd or can i lay it as a floating floor like you do laminate.thanks for anyones help .
J.G.F
Re: floating floor
by J.G.F » Wed Feb 18, 2009 11:14 am
[quote="raddish"]sorry if you didnt catch my drift . my existing floor is large chipbourd flooring sheets fixed directly to the joists,so i do not want to remove these.but want t&g floorbourds so i can paint the floor. my dilema is do i fix each bourd or can i lay it as a floating floor like you do laminate.thanks for anyones help .[/quote]
Personalty i would secret nail them, you can float the boards just put glue in each of the grooves and knock them together. Remember your Expansion though.
rosebery
by rosebery » Wed Feb 18, 2009 3:37 pm
"Personally i would secret nail them"
I was thinking the same thing actually.
It is currently Wed Nov 27, 2024 2:28 pm
