Ideal Standard Dual Flush
landau1945
by landau1945 » Sun Feb 15, 2009 12:51 pm
I have an Ideal Standard dual flush toilet.I want to take the cistern cover off to clean behind and put a loo block in..Following instructions I took out the push buttons and then wanted to unscrew the screw inside to release the thingy???? enabling cistern cover removal.
Problem is the screw has a long shallowish slot in it and is made of plastic or nylon and of course is screwed in so tight it won't budge.I'm worried that it might break if I push down too hard or the whole mechanism might turn round inside.
Any ideas out there?
rosebery
by rosebery » Sun Feb 15, 2009 11:47 pm
It should turn but make sure you use the right sized 'driver to fit the slot.
Alternatively hang you loo block over the edge of the pan in oine of those plastic cage thingys.
plumbbob
by plumbbob » Mon Feb 16, 2009 8:28 pm
As Rosebery says, it will undo, but consider that it is not designed to be repeatedly removed which you will have to do if you want to keep adding one of those loo blocks.
As a plumber, frankly, I hate those blocks as they stain everything and any repairs or adjustments leave me with blue fingers for the next two days.
It is currently Fri Jan 31, 2025 6:13 am
