Odd Smell...
heathmount
Odd Smell...
by heathmount » Mon Feb 16, 2009 7:57 pm
Don't worry - I've not got a gas leak!
Evey now and then when I use my gas cooker (like now) there's a smell coming off it which is not gas but more of a paraffin type smell. Currently I have the oven and one of the rings going, have been for about half an hour and the smell is very noticeable. It's obviously not a gas leak or I woldn;t be writing this! Any ideas? We have gas central heating but it's only ever when the cooker is on and then only sometimes.
cheers
Dan2071
by Dan2071 » Mon Feb 16, 2009 11:19 pm
It could be a small gas leak, or maybe a burner hasn't lite properly? Also, could just need a clean? I've seen some pretty bad ones.
Dan
willie gas
by willie gas » Sun May 10, 2009 4:36 pm
HI i have just started looking at this site, the strange smell is because u was using a gas burner in a property were fresh paint had been used somewhere in the property.
by htg engineer » Sun May 10, 2009 5:04 pm
Could be few things - if you're sure it's not gas.
The cleaners you use on the oven/hob - can give off quite a strong smell when heated - is it when the hob or oven is used ?
Also worth removing and cleaning the hob burners, if you remove the burners you may find underneath is full of water, grease etc.
htg
swatt66
by swatt66 » Thu Nov 18, 2010 1:42 pm
When you have oil-based paint drying the burning gas smells funny. I don't know why but it just does.
It is currently Fri Nov 22, 2024 8:10 pm
