candy cic60 condenser tumble dryer
ptg1174
by ptg1174 » Wed Feb 18, 2009 2:17 am
hi my candy cic 60 dryer keeps triping my house electric everytime i plug it in i had a problem with no heat and replaced thermal fuse which did the trick but now it keeps triping and is a real pain would love to repair rather than replace please help
wimiu012uk
by wimiu012uk » Sat Feb 21, 2009 6:52 am
You say it keeps tripping.
When it trips does it then trip the house electrics ?
If the dryer keeps tripping you may of installed the wrong stats for the machine as there are several ones availiable, check that you have bought the right ones.
If it trips the house electrics when plugging in check the plug as some wires could have broken causing a short.
ptg1174
by ptg1174 » Wed Feb 25, 2009 1:05 am
correct part fitted bought from maplins, it does keep triping house electric
the plug is a sealed plug i will try changing it
ptg1174
by ptg1174 » Thu Feb 26, 2009 1:28 am
changed plug same result when plug in it still trips house electrics ?
It is currently Fri Nov 15, 2024 1:43 am
