Laying Patio Slabs
slaphead
Laying Patio Slabs
by slaphead » Wed Feb 18, 2009 6:25 pm
I want to lay slabs on top of old crazy paving that has been down for years,The area is quite flat and drains well and I dont want to take up the crazy paving,I would like some advise on how to prepare the area and what mix to use.
Thanking you in advance.
Roger.
by stoneyboy » Fri Feb 20, 2009 8:41 pm
slaphead,
Assuming foot traffic only use dobs of a 4:1 sand cement under the new slabs. Grout the joins after set with the same mix.
elwood
by elwood » Sat Feb 21, 2009 6:21 pm
If your are inexperienced at laying slabs the best method is,
find the highest point on the existing patio, this will be your starting level.
set up some screed rails allowing a 30mm bed above your highest point,
allow for falls required.
mix sharp sand and cement 4 to 1 mix (put through a mixer)slighty damp.
roughly spread the mix around, then level off by dragging a straight rail
over the screed rails leveling the mix .
lay slabs.
if pointing is required use 4 to 1 mix including fed mix and building sand
just mix workable amounts at a time making sure you gauge the mix every time.
Be aware of your new finished level and DPC on your house
It is currently Tue Nov 26, 2024 12:28 pm
