External Weatherbar
paulsax
External Weatherbar
by paulsax » Thu Feb 19, 2009 10:51 pm
Can anyone advise the method for installing a timber weatherbar to rebated double French doors (opening in) Its the method of cutting the weatherbar I require in order that it does not foul-up on the adjacent door when opening the lead door only? Many thanks :)
rosebery
by rosebery » Sat Feb 21, 2009 12:34 am
You need to mitre both sides.
paulsax
by paulsax » Sat Feb 21, 2009 3:26 pm
Many thanks for replying; however, i've tried mitreing both sides (from the middle) at 45 degrees but it still catches the other door. I just wondered f there was a 'special' angle which the cart should be cut at to pevent this happening?
rosebery
by rosebery » Sat Feb 21, 2009 7:52 pm
Trial and error usually works in these circumstances. Only make small cuts at one time. You can always cut more off but you can't stick a piece back on!!
It is currently Thu Jan 09, 2025 6:45 pm
