lead oxidisation
minties mate
lead oxidisation
by minties mate » Fri Feb 20, 2009 1:32 pm
i recently had lead flashing put on a new extension roof, leaving a tiny flat area for me to finish off. when the guy who did the flashing finished, he rubbed a solution into the lead which gave it a darker appearance. i have now added the final flat area but its much brighter than the other. can anyone tell me what he may of used??
thanks in advance
by stoneyboy » Fri Feb 20, 2009 8:45 pm
minties mate,
He's probably used patination oil available from builders merchants.
rosebery
by rosebery » Fri Feb 20, 2009 11:40 pm
Patination Oil.
Keane Roofing
Lead Effect
by Keane Roofing » Mon Mar 23, 2009 10:26 pm
If you have no luck with oil which you should have uf you to builders yard, WD40 is the next best thing. Good luck
It is currently Wed Jan 01, 2025 5:40 am
