laminate flooring
tina2107
laminate flooring
by tina2107 » Fri Feb 20, 2009 9:11 pm
do i need to glue every joint on a laminate floor incase of spilages or will it just form a puddle
by stoneyboy » Sat Feb 21, 2009 4:11 pm
tina2107,
No you do not need to glue joints, if you do have a spill do not allow the water to lay on the surface of the joint. If you want the laminate for a bathroom then use one of the laminates specifically design for use in damp areas eg aqualoc.
It is currently Tue Dec 24, 2024 4:41 pm
