single skin external wall problem
doitwell
by doitwell » Fri Feb 20, 2009 11:24 pm
Hi guys ... I hope someone will have an answer to this problem ... I've been asked to plaster a conversion, garage to utility/shower, but one of the external walls is single block. Plastering isn't a problem but I would like to fix stud, board and insulation to this area without eating into the limited space ... what is the best solution that will provide a damp proof/insulated wall
kbrownie
by kbrownie » Tue Feb 24, 2009 8:34 pm
apply liquid d.p.m on to wall, then fix stud work, insulated in between stud work, then vapour check barrier over stud, then board.
KB
It is currently Sun Nov 24, 2024 9:33 am
