Why Hardcore under concrete bases? what effect does this hav
kendellsteve
by kendellsteve » Sat Feb 21, 2009 8:01 pm
Could some one just solve a little querie of mine
Why use Hardcore under concrete bases? what effect does this have on the foundation, and can i use gravel instead.
eljaybee
by eljaybee » Sun Feb 22, 2009 7:58 pm
Couldn't make sense of your post until I had a brainwave and that the title and post may have been edited by the site admin - Where you actually asking as to why use a building material known as the following two words combined together in the reverse order than I have given here "core" and "hard"
If it is then I would have though on a DIY site they knew that this world is the correct term for a material used as a concrete floor sub-base!!!!
Anyway - the reason why you need to use it instead of gravel is that you need to compact it to give a firm base - thus you need the pieces of all sizes inculding the fines (dust) to bond together when compacted - with just gravel you won't get this bonding.
Hope that answers it for you!!!
rosebery
by rosebery » Sun Feb 22, 2009 8:08 pm
Forum software strikes again!! LoL. Although I could guess what word did you use that has been censored? Try spelling it out with a space between esch letter.
It is currently Mon Jan 20, 2025 2:52 pm
