kitchen wall units?
roberto
kitchen wall units?
by roberto » Sat Feb 21, 2009 8:26 pm
how big does the gap between my worktop and wall units have to be?
by stoneyboy » Fri Feb 27, 2009 6:43 pm
roberto,
There are fairly strict requirement for the height of wall units either side and above a hob/cooker - these will dictate the minimum space needed.
sweetorb
by sweetorb » Sat Feb 28, 2009 10:37 am
hi
i normally take into account which tiles and how many rows are goin in when setting a height for wall units. the "standard" height is about 18 inches,ie 3 rows of 6" tiles. sometimes tho if the customer has chosen 8" tiles ill set them at 16" ie 2 rows of 8" tiles. or add another 2" if theres a small row of border tiles,either way,for practicallities sake i certainly wouldnt set them higher than 20" at an absolute max!
hope this helps
mark
gerryyy
by gerryyy » Mon May 04, 2009 9:35 pm
If you have a full length unit or a dresser unit, use the top of this as your overall height and keep wall units same height! usually kitchen units are 2120mm high, so the top of your wall unit should be 2120. SO
2120 - 720MM WALL UNIT = 1400mm to bottom of wall unit
most worktops are 910mm high, so gap would be 490mm
It is currently Fri Nov 22, 2024 9:05 pm
