concrete rafts
Ask questions and find answers on a range of subjects relating to self build projects
pete m
concrete rafts
by pete m » Sun May 20, 2007 12:09 pm
hello everybody this is my first post great site can learn loads spot on.
I build concrete prefab garages and sheds for a living,these are built on rafts usually 3-4inches deep,the builbing weighs approx2-3tonnes (no problems).My question is can a raft be used instead of traditional type footings to build a conservatory,as i see it a lot less weight will be going on the slab as apposed to a garage.thanks in advice for any replies. :?
thedoctor
by thedoctor » Sun May 20, 2007 8:49 pm
Can be done using a ring beam round the peremeter of the raft usually Pete but a good idea to get advice from your local building inspector as the ground conditions play a big part.
pete m
by pete m » Mon May 21, 2007 5:10 pm
thanks for reply.will check it out with inspector. :wink:
It is currently Sun Dec 22, 2024 12:13 pm
