LOW HOT WATER PRESSURE
diyman1956
by diyman1956 » Sun Feb 22, 2009 11:27 am
Hi there everyone
My mother has just moved into a ground floor apartment, the problem is low water pressure at the hot tap in the kitchen.
There is a long run of pipe work to this tap from the hot tank and I understand that because there is not a lot of height from the cold water feed tank to the hot water tank, that this may well be the problem??. My question is:assuming what I have said above is correct , is there anything on the market that can be put into the system to increase the pressure at the tap ??
by stoneyboy » Fri Feb 27, 2009 6:44 pm
diyman1956,
Yes a single impeller pump but it won't be cheap.
It is currently Wed Jan 01, 2025 5:45 am
