Bleeding Central heating
daniel foss
by daniel foss » Sun Feb 22, 2009 4:14 pm
I have just fitted some new radiators which required draining the system down as some pipe lengths needed to be altered.
I need to find the correct method of bleeding the system, usually I bleed the radiators, pump and 2 high level bleeders (1 above the pump and 1 at the top of cylinder coil) with the system turned off however there is still air in the system as it gurgles and bangs away when first starting up.
Also 1 of the rads, furthest from the pump won't heat up so guess an airlock is to blame.
System is indirect vented.
Thanks, Daniel
by htg engineer » Sun Feb 22, 2009 8:32 pm
Fill from the bottom up - all downstairs rads, upstairs rads, then the two manual airvents, and also the pump.
There's nearly always some air left - it wont harm anything. To solve the problem with one rad not heating, turn off all other radiators and see if it comes through.
htg
It is currently Mon Nov 25, 2024 6:33 pm
