Electric oven and hob
Hutch4m
by Hutch4m » Sun May 20, 2007 7:00 pm
I've just purchased a new electric oven and electric ceramic hob and I am in the process of fitting it. I originally had a gas hob and an electric oven. My question is this: Can I connect the new oven, which has a max power output of 2.77Kw, into the socket which provided the ignition for the gas hob? It has a 13amp fuse and I think it's 1.5mm cable. Also can I connect the hob to the old oven socket? The hob has a max output of 5510Kw and it looks llike the socket is 4mm cable.
Any replies would be greatly appreciated!
Jeffmo
by Jeffmo » Sun May 20, 2007 11:19 pm
hi , the oven should be fine in the socket you mention , not quite sure about the hob as it runs at about 27 amp . cheers Jeff
Hutch4m
by Hutch4m » Mon May 21, 2007 11:34 am
Thanks Jeff, I've tried the oven and it seems to be working fine. I'm pretty sure the cooker MCB is 32A (I'm at work at the mo so I can't check) and the hob would never draw that much.
Should be fine,
Thanks for the reply.
Hutch4m
by Hutch4m » Mon May 21, 2007 5:33 pm
I've checked the cable and it looks like 6mm so with a 32A fuse (MCB) that sounds right. I'm going to go for it, what's the worst that can happen!?! :wink:
It is currently Sat Jan 11, 2025 10:04 pm
