opening a new doorway
7 posts   •   Page 1 of 1
liltodge
by liltodge » Thu Feb 26, 2009 10:53 am
im knocking through a new door way(2ft 6in wide),i was thinking of using a 1200mmx200mm concrete lintel,the new door way would be on the ground floor and it's an exterior wall.the wall i would be knocking through is a 2 storey wall.would that size lintel be o.k????????
by stoneyboy » Fri Feb 27, 2009 10:08 pm
liltodge,
A lot will depend on what openings are around the proposed doorway. I would strongly recommend you get a surveyor to have a look and suggest alternatives.
dardar29
opening a doorway
by dardar29 » Tue Sep 29, 2009 11:25 pm
Hi guys, avid diy enthusiast here, first time opening a doorway, small one storey extension, unsure of brickwork, whats the best lintel to use and how do i fit it? cheers.
by stoneyboy » Mon Oct 05, 2009 9:26 pm
dardar29,
Sorry can't really say unless you give details of what is above the opening eg bricks, roof tiled, roof flat ......
dardar29
doorway
by dardar29 » Tue Oct 06, 2009 10:05 am
theres about four courses of brick than a tiled sloping roof
by stoneyboy » Thu Oct 08, 2009 11:33 pm
dardar29,
Do the ceiling rafters run parallel or at right angles to the proposed opening?
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 05, 2010 7:39 pm
Find trusted, insured and vetted tradesman local to your area. Visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sun Dec 22, 2024 1:18 pm
