Concrete Formers.
gonzosaxman
Concrete Formers.
by gonzosaxman » Sun May 20, 2007 10:24 pm
I'm planning to build a deck on sloping ground, and want to create concrete foundations which raise up above ground level. In order to do this, I think I need something called a former - a thick cardboard (or something) tube or box which I set into the ground and pour my concrete into. The cardboard (or something) has to be thick and dense enough, not to go soggy I presume???
Can anyone help me source these formers? I have looked in most of the local DIY shops and have drawn a blank! I think what I need is a tube or box former of around 8 inches in diameter.
Gonzo
thedoctor
by thedoctor » Wed May 23, 2007 7:37 am
You need a builders merchants not a diy shop Gonzo. Plywood is the minimum thickness and strength you need but for this type it would be a great idea to use a large drain pipe secion which you could place thye concrete in the centre of.
It is currently Fri Jan 31, 2025 1:29 am
