Help me wife bending my ears
HBRIT63
by HBRIT63 » Sat Feb 28, 2009 8:06 pm
I’m having a problem too with ceiling light fitting. The new lamp has the following connections Blue and Black and no earth !, The rose ball has three main wire connectors first has three slots = 1 black and the middle has three slots = two red wires and the final one has two slots and one black wire.
i've tried and i get the light to go on but the switch will not turn it off. Can anyone help me wife's bending my ears HELP .
steve
by stoneyboy » Sun Mar 01, 2009 5:25 pm
HBRIT63,
Try connecting the new light to the two connectors with the single wires - not to the one with the two red wires.
rosebery
by rosebery » Sun Mar 01, 2009 7:11 pm
If you haven't changed anything in the ceiling rose then connect the light wires to the two end connectors on the rose like Sb says. It sounds as though you have one connection in one end and the other in the middle section.
Also look in projects on this site where you will find a diagram.
moggy1968
by moggy1968 » Sun Mar 01, 2009 9:02 pm
reason your light is on all the time is because you've connected the live on the lamp to the permanent live feed (the reds) you need to connect to the switch wire, follow the directions above. the only proviso to this is that if the new fitting is an eddison screw you must identify the switch live and connect this to the centre connection of the lamp (Live). the switch live is usually, but sadly not always, identified by a red or brown sleeving or tape over the black wire.
HBRIT63
Re: Help me wife bending my ears
by HBRIT63 » Mon Mar 02, 2009 12:09 pm
Thanks guys was a big help lights up and running now
steve
It is currently Sun Jan 19, 2025 8:36 am
